Backstory: I had been looking for a USA gen 2 (2012-2015) Mazda5 with the 6 speed manual for a while. Only around 1000 exist in the USA so when I found a cheap one, I jumped on it. This car was not well cared for in its 182k miles prior to my ownership. This car had the OEM mazda spark plugs dated 2013 in it with a wildly big gap. The serpentine belt was so crusty that even when I cut it, it stayed in place and held tension. Ive been slowly rehabbing this vehicle and have replaced nearly every wear component.
The car runs great and the engine makes no noise. It asks for 0w20 and when I initially changed it after purchasing the car, the oil had a good amount of sparkles in it. I assume the oil was changed very infrequently prior to my ownership, though, under the valve cover is surprisingly sludge free.
If this was your car, what engine oil would you run?
