- Joined
- Dec 30, 2006
- Messages
- 29,568
Redline Shockproof Heavyuntil I start filling it with gear oil.
Run a quart of HPL Engine cleaner thru it. Might help?
as others have written, why not try a heavier weight oil? this toyota’s 105hp engine is found everywhere in southeast asia, where big box retailers, gas stations and hardware stores (including ace, which has a big shopping mall presence there) pretty much stock only x-w40 weight motor oils.Scion xB
Boy, did I get taken…
I recently bought a 2009 Scion xB with the 2az-fe engine. It’s an oil burner. I filled it to the top mark yesterday before taking a 300 mile trip, almost all 70mph interstate driving. I checked the oil this morning and it’s barely touching the bottom of the dipstick. Because it’s a 2009 it’s...bobistheoilguy.com
I‘ve been soaking the rings for a couple of days. I’ve never heard of HPL engine cleaner
Harvest King/Providence brand is $11~ 5quart jug at Rural Kingtl:dr What’s the cheapest decent oil you can buy?
I just bought a used car and it’s an extreme oil burner. If my hillbilly fixes don’t work I’m going to need about a quart at every fill up. Right now I can buy a five quart bottle of Providence Automotive brand conventional oil from Rural King for $11.99, which translates to $2.40 a quart. That’s cheaper than Supertech. Any cheaper oil that meets API spec? I’m probably going to be burning either 10w-30 or 10w-40.
Wow, I didn’t realize that oil was S rated. The Traveller brand from Tractor Supply is only C rated.good and cheap
From what I’ve read some people have been able to run this particular motor a lot of miles just by switching to a heavier oil. It’s a known issue.Burning that much oil I would not worry about oil being API, just keep oil in it. The pins out of the grenade on that motor...
It is but it's an older license and contains around 1150ppm of phos, they can still claim CK-4\SN until the license expires as it was issued prior to the new API rules about dual rated HDEOs that require a dual rated HDEOs to adhere the the resource conserving S-rating, the big blenders like Exxon-Mobil, Shell, and Chevron decided to adhere to the 800ppm rule a while ago, but Valvoline and several other small blenders still continued selling CK-4\SN rated oils that exceeded the phos limits.Wow, I didn’t realize that oil was S rated.
