I'm going to take delivery in a little while of a new MB Roadster, the SLC 300. It will have a 2.0L inline 4. What I don't know is which oil viscosity is actual or recommended for the vehicle. The owner's manual is surprisingly uninformative as to what oil to put in it, other than that it must meet the 229.5 specification. I do not know what the factory fill is. In fact, they don't even tell me what the engine model/number is, so I'm having trouble researching this.
The 229.5 spec includes many approved oils of various viscosities, but I don't know which to use. Also, if you take a look at the 224.1spec, Viscosity classes of engine oils (car engines), it, too, is ambiguous as to which one to use. As far as what these spec documents say, it could be 0W-30, 0W-40, 5W-30, 5W-40. I'm savvy enough to know that it's not the case that any would do; if I knew the factory fill, I'd simply copy that.
This is a car that will be driven in Southern California. It will rarely see freezing temps, but it's likely to go to the central valley or the desert areas where the temp might be 35-40°C.
Also, if you're familiar with Mercedes manufacturing and what might be the factory oil, can you tell me if it's a 10K mile oil? Should I go that long, or change it before then? I won't be taking it to a dealer for oil service, so I need to know what to put in it. MB doesn't make it easy. Thanks for your help.
