lawn Tractor Oil filters
USA
Picked up a box of lawn mower filters at a yard sale this weekend. All appear to fit the Briggs/Kohler/Kawasaki engines popular on lawn and garden tractors. All are ~ 2.3 inches in height except the NAPA Gold 1056 is ~ 2.8 inches. Observations: 1) The Briggs 696854 filter is made in India 2) The Kawasaki 49065-7007 filter is made in the USA appears to have a silicon ADBV and a baseplate common to Champion Labs filters. 3) WIX/NAPA 57035/1056 appear to be the same construction except for the height 2.3 vs 2.8.
The Old North State
I just run the Napa Gold 1348 (Wix 51348) automotive application OF on Kohler engine ride on. Silicone adbv and I find significantly less expensive the OPE filters. But, I have room for the ~.75" extra length over the 5/1056.
smithph
USA
Good point on the extra length. My setup has a plastic shield that would cause the end of a ~ 3 inch filter to touch. Often thought of taking a hole saw to it and making room for a longer filter laugh Sorry but cannot answer the questions as to why filters designed for air cooled engines have an ADBV.
Canada
I have always used the very common 3614 type filter on these engines, the extra length makes it much easier to get a grip on the filter when changing, they are available anywhere and cost a fraction of what the standard filter costs. I know local landscape companies that do the same.
Connecticut
I usually use the Napa Gold, but have the use the shorter one (like the Wix) on a few machines due to the longer filter not fitting. On my grandfather's Scag mower for example, the filter is right next to part of the frame. Using a longer filter is impossible since I can't even screw it on.
Central Wisconsin
As the filters on lawn tractors and zero turn mowers sit horizontally, a ADBV would reduce the oil spill when removing them. The Fram filter that crosses for Briggs and Kawasaki mower engines is $4, but Wal-mart doesn't carry it IN STORE. Has to be ordered on line from a secondary supplier. My 2¢
TN
Just bought two Motorcraft FL-910S filters for my Briggs riders. I think the were $3.57 each at Walmart.
Virginia
Just got some white can (Wix) ST3600 filters for $1.50 each at Maul-Mart... 5 inches long verses three and a half for the 3614... Also a few ST8’s..
smithph
USA
FYI, I had the opportunity to put my hands on and eyeball an ACDelco PF2210 and a Fram PH8172, both 2.7/2.8 inches in length. Both made in the USA and appear to be very similar in construction to the 2.3 inch Kawasaki filter (Champion Labs) minus the silicone ADBV.
smithph
USA
Thought I would repost this list developed by Bill Kapaun back in the day.
Code:
Bill Kapaun's Lawn Mower Oil Filters Cross Reference
Length  Wix     Purolator  Hastings  Kohler   B&S     Baldwin  MotorCraft  AC     Fram
2.3"	57035	NA	   LF503     2805001  492932  B7165    N/A	   N/A    PF8170
2.7"	51056	L35310	   LF302     1205001  492056  B1410    N/A	   PF2210 PF8172
3.4"	51348	L10241	   LF157     5205002  491056  BT223    FL793	   PF53   PF3614
4.8"	51516	L20195	   LF134     277233   N/A     B243     FL400A	   PF56   PF3600
"Briggs/Kohler type" 3/4" X 16 threads 8-11 PSI Bypass Gasket 2.734"OD X2 .430"ID 0.226" thick
JTK
Buffalo, NY
Yep. Refer to good'ol Bill Kapauns's chart is my suggestion. That baby has gotten a LOT of use over the years here and elsewhere. If I don't have a filter on hand, I'll usually run the largest/longest that will safely and effectively fit. I currently have 3-4 "Champ" PF53 equivalents for my Craftsman rider with a 17.5hp Briggs that I bought off eBay cheap years ago. If you cut open one of those ~2.3" OEM length filters, the media end caps take up most of the space inside the filter, offering only a little strip of media. I'm sure that little strip is fine for these tiny engines, but I like the extra oil holding capacity offered by a physically larger filter.
smithph
USA
Code:
2.3"	57035	NA	   LF503     2805001  492932  B7165    N/A	   N/A    PH8170
2.7"	51056	L35310	   LF302     1205001  492056  B1410    N/A	   PF2210 PH8172
3.4"	51348	L10241	   LF157     5205002  491056  BT223    FL793	   PF53   PH3614
4.8"	51516	L20195	   LF134     277233   N/A     B243     FL400A	   PF56   PH3600
Just noticed I fat fingered the Fram listings, sorry Bill. They should be PHxxxx not PFxxxx
