Large debris found in factory oil filter, now what?
Did my first oil change on my new Rav4 at 2500 miles. Saved the filter to open it up when I had time. I opened it this past weekend and was not happy with what I found inside.
There were 4 aluminum shards just under the size of a pencil eraser, some thinner peices that looked like fine nail clippings, and generally a lot of debris in the filter pleats. Lots of what looks like yellow paint which I think is from the valve springs. Lots of general debris in the remaining oil in it. Question is where do I go from here? I have already done 3 oil changes and I am at about 8 k miles. Took the second filter apart and it looked a lot better. When is a good time to do a uoa to make sure things are okay?
Yep, that is what the first oil filter will typically look like. UOAs are a waste of money until about 40k. Even then there will not be much to see as long as the oil was changed regularly. You should see the rear end of a John Deere tractor hydro fluid change, chunks and chunks of RTV. Or buy yourself a Predator generator and see how nice it is after a 3 hour break in.
Keep on moving. Toyota isn't going to pay a dealership to chase ghosts.
I don't know, but it seems like the oil filter was working as designed. If you have done, say, 5 oil changes on the vehicle, and you cut open that filter, and still have chunks, I'd continue to document and notify Toyota. But if it's only the first one? I wouldn't worry so much.
Do you intend to keep this vehicle past 200K miles or trade in in a few years? Unless you intend to keep it "forever" this will probably never matter.
Toyota might call that "machining debris" but who really knows. Have you tried using a magnet to see if anything sticks?
These kinds of posts is why many folks like to do an early flush of the factory fill stuff.
Yep Toyota have been blaming everything on machining debris lately.
I hear you. I've cut open lots of factory filters over the past ~20yrs and if I find anything, it's never been that much. If all is well now, it's likely going to stay that way. Just keep up on your oil change documentation to support you've done them per Toyota recommendations.
There were 4 aluminum shards just under the size of a pencil eraser, some thinner pieces that looked like fine nail clippings, and generally a lot of debris in the filter pleats.
Okay, it took me a couple of tries to understand everything.
Your car is currently at 8k mile mark, and you've already done 3 oil changes.
This oil filter was actually from your first oil change at 2500 miles, and you decided to cut it open, because Halloween isn't coming fast enough for you, and you needed a good scare.
The yellow paint is most likely from the engine builders when they mark the various bolts when they are torqued down to the correct specs. So, nothing to worry about there.
The bigger piece is just flashing from the block or head casting, and that is also normal.
The oil filter did a great job of capturing that, and not allowing it to get sucked into the oil pump, or going further downstream into the crankshaft or cylinder head journals.
Where do you go from here?
Nowhere.
If your engine sounds normal, then all is good.
Its that simple.
That's why, again, we dump first change early. Always have, but others don't agree.
I cut open the factory oil filter on our Mazda CX-5 at 2,300 miles. Super clean. I was expecting some tiny little things, but it was remarkably clean. Have had others that had a lot.
Cut open the next filter. Probably looks fine.
