Hi guys, I would like to ask something very important to me . I mean, I own a Land Rover Defender 90 Td5 MY 2006 and I like to do maintenance on my own. I would like to know more about gearbox oil. In the maintenance manual for my gearbox oil ( R380 ) is only recommended Texaco MTF 94 , SAE 75W80 , API GL-4 but since I would like to put a synthetic oil, since it is not easy to found...
I would like to understand :
1 ) Is this oil so miraculous to be explicitly recommended?
2 ) reasoning, I do not think that Texaco MTF 94 is used around the world in Land Rover Defender Td5's gearbox
Doing some research, Castrol website says that for my car I can use Castrol Syntrans Multivehicle 75W-90 API GL-4. This oil is synthetic and I could also find it easily.
I would like to ask you, as I want to learn, what can I put in my gearbox on oil change? a generic API -4 75W90 oil like Castrol Syntrans Multivehicle can be used aswell? If you know any database can you try what I can use: Land Rover Defender 90 Td5 MY2006
Thanks a lot to who will answes.
