I've come to appreciate his videos. Something he did not address, this brings to mind the recent Toyota engine failures, where a single main bearing and its adjacent connecting rod seems to starve for oil. Ultra low viscosity oil does flow out of any escape faster (anything provided with oil pressure that has flow) and may not reach the far end or highest point, under low RPM (or low oil pump flow) conditions. Especially when some wear and therefore faster flow, sets in.
Also, while UOA results are great for troubleshooting and monitoring, they really don't reflect wear rates. Physical measurement is required. Some time back, I tried ultra thin oil in a high performance 4 cylinder, in an attempt at more HP. What I got was 250ppm Pb from the bearings. Which was one of many factors in deciding to perform an overhaul. The bearings were visibly fine. My point, clearly there was a much higher level of nano particulate lead. But there was no visible bearing damage.
On my aircraft engine, I pull oil pressure from the front end (front of the engine) of the oil gallery. It reads as much as 10PSI lower here than it does at the feed point (on the back of the engine) . Yeah, I know what you are thinking, the oil pressure should be the same everywhere. But this situation is well established, and the farthest point is the best place to measure pressure.
