Originally Posted By: UltrafanUK
Did not quite finish my last post!
I think this kreen stuff is supposed to be used as both an oil and gas additive, as is the old fashion MMO. In my opinion you can't design an additive that works well in both the oil and fuel.
I asked LM R&D who make both oil and fuel additives why their oil scourer could not be used as an injection system cleaner and he said it was not a good idea as some of the oil seals and plastic components used in the fuel system are not compatible with the chemicals in a good flush. When MMO was tested as a fuel additive in comparison with other oil additives recommended for alternate use in the fuel, it did almost nothing and the big surprise was that Bio diesel turned out to be the best solvent and upper cylinder lubricant.
Blue smoke on start can be caused by both a worn block (Bad rings in particular), a turbo oil seal failure or oily deposts in the intake. A leaking HG can also cause blue smoke on cold starts, but I doubt if bad injectors would cause it.
In conclusion if you want to use oil or fuel additives, stick to major brand companies like Amsoil, Castrol (They make a good idle use oil flush), Liqui Moly, Lubeguard or B&G. Stay away from back street mixers and do not use oil additives in a vehicle under warranty without written clearance (An e-mail from a business address is OK) from the dealership.
Excellent posts! Just wanted to add that this is a Boxer H-6 Motor, so soaks would be pointless. I checked the CCV and it is working fine. These motors are starting to get a reputation for bad head gaskets at about this mileage. I'd doubt that is the cause, but never stopped to think about this.
I'll go ahead and take heed to your advice.
Cheers M8.
