Just another Kreen believer...
Originally Posted by spasm3
Originally Posted by SteveSRT8
Propflux, the intake would have to be hot and the kreen introduced as a vapor for even a chance of even distribution. Dry intakes are not designed for the pooling and uneven distribution of a liquid.
That's the issue i worry about, even when i use the CRC cleaner, is intake pooling. It could pool in the intake, you go out for a drive, and when you really step on it, there is enough flow to pull a lot of the liquid into the closest cylinder to the pooled cleaner, and bam! Busted piston or connecting rod from hydrolock.
I have used the CRC intake valve cleaner in the mazda. But i only used 1/2 a can, not the whole thing, for fear of pooling. After it sat an hour i went for a 10-15 mile drive, but i did not let it rev over 3k.
I was used the GDi cleaning spray every other oil change at roughly 10% so I could get 10x usage. Looked good at 200k on the Hyundai. I think the prevention maintenance is the best action to take.
I think i am going to use it( the crc product) before every oil change. Not the whole can, but 1/3 or 1/2.
