Off topic:
Quote:
I have twin 440s in my boat. One of them has excessive crankcase pressure, thus oil usage.
I took a new ship out of the shipbuilder that had three 2mW MAK diesel generator engines (2700 hp), straight eight, 32 cm bore (12.6"), 600 rpm. One of these new engines used a LOT of oil. The factory tech checked everything and finally started taking the crankcase venting apart--several hundred feet of 4" pipe. He found one flanged joint where the cardboard cover over the end for cleanliness had not been removed after the pipe left the fabrication shop and was assembled in the ship. Oil consumption dropped to just about nothing after that.
Back to Kreen. I have two engines that burn more oil than they should, a Volvo turbo with 195,000 miles, and a VW V-6 with only 45,000. A thousand miles before the next oil change, I'll put a pint of Kreen in each and see what happens.
Bushwood, do you think the excess crankcase pressure is due to combustion gases blowing by stuck rings? If the Kreen cleans it this time, how will keep them from getting stuck next time? More robust oil? Run them hard periodically?
