Trav
If the engine does not use hydraulic lash adjusters (i don't know what it has of the top of my head) Kreen or anything else will not help with the noise, it needs a manual valve adjustment.
You plan is fine i would add 10oz to the oil after you do the piston soak and OC and leave it at that, i wouldn't top off with Kreen if the level goes down a bit.
Save the remaining Kreen for the next OC and use a full bottle of Redline Sl-1 initially then smaller doses at regular intervals to keep it clean.
