QuakerState 5w50 96.1
Pennzoil 5w20 45.9
Most don't have a clue what the bottle label means..... "it acts like a 5 when cold and a 30 when hot" is the best that the consumer can say and is false and means NOTHING, but is all that many think and for obvious reasons.... brainless MARKETING and for the sake simplicity.
Below is the prefix/suffix SAE grading system. There are also non-SAE grades that some blenders use(and need to define).
An oil can be a single prefix, or single suffix only, or a multgrade with 1 prefix and 1 suffix, to help prevent consumer confusion. So, you won't see anymore 0w5w10w15w-30 oils or 0w-16,20 or 5w-16,20 oils. So, my SAE30/10w30 VPracing small engine oil is incorrectly labelled.
Both thick or thin 'labelled' oils can pass the 5w grade but I promise you that a 5w50 is going to considerably thicker than a 5w20 when cold. Years ago, some of the boutique oil brand provides viscosity curves for their grades. I didn't save the pamphlets but seeing the curves, at various temps, made you wonder what SAE was thinking and can improve upon. To SAE, the 40 degree viscosity measurement is meaningless and useless for their grading system.
