Hey folks, just purchased a 2021 Kia Seltos SX Turbo that has a DCT. Right around 34000 miles on it. Is there anything special about Kia OEM fluid, or is there an equivalent aftermarket brand that would work? I think the OM calls for an API GL-4, SAE 70w. And I assume it is the standard drain hole on the bottom/fill hole on the top, drain and refill with how much you took out procedure? Thanks in advance!
