Kendall GT-1 Blend
Decatur AL USA
I was looking at the new SP GF-6A Kendall GT-1 Blends and noticed something.
Misread the MDS. Never mind.
Kendall has titanium in its add pack, I do not think MC oil does.
Two different oils:
1. Kendall GT-1 High Performance Blend SP GF-6A
2. Kendall GT-1 High Performance Blend with Titanium SP GF-6A.
I was comparing Kendall #1 to P66 and MC.
It does have something called LiquiTek. Whether that amounts to something other than marketing babble I can't say.
Just need to ping them and ask what Liqui-Tek is...
Here you go:
Now whether that means Liqui-Tek is titanium rebranded or if it means they no longer use titanium remains to be seen.
Well like I said they list with
Here you go:
It appears to be two different things.
They list two different blends.
GT-1 High Performance Motor Oil with LiquiTek.
GT-1 High Performance Motor Oil with Liquid Titanium.
The Liquid Titanium Product shows an ever so slightly lower flashpoint and VI on the MDS. Possibly because of a slight increase in G1 carrier oil with the Liquid Titanium.
Scroll down in the link I posted, it is all changing to Liqui-Tek.
Note the photo:
Note the photo:
Got you. I finally found a MC GF-6 spec sheet. The 5W-30 is lower viscosity, higher specific gravity, lower viscosity in the cranking test and has higher VI. But the differences are seemingly minor..
Kendall, "The Two Thousand Mile Oil."
That's pretty good for a Nitro burning Top Fuel Car when the rods, pistons, rings and bearings only lasted 1/4 mi.
("Big Daddy" Don Garlits reference for you infants out there).
PS I know the historical context of your reference but might give the infants the wrong idea.
