Kendall GT-1 Blend
Gene K
Decatur AL USA
Kendall has titanium in its add pack, I do not think MC oil does.
Two different oils:
1. Kendall GT-1 High Performance Blend SP GF-6A
2. Kendall GT-1 High Performance Blend with Titanium SP GF-6A.
I was comparing Kendall #1 to P66 and MC.
It does have something called LiquiTek. Whether that amounts to something other than marketing babble I can't say.
Gene K
Decatur AL USA
Just need to ping them and ask what Liqui-Tek is...
Here you go:
Now whether that means Liqui-Tek is titanium rebranded or if it means they no longer use titanium remains to be seen.
Well like I said they list with
Here you go:
It appears to be two different things.
They list two different blends.
GT-1 High Performance Motor Oil with LiquiTek.
GT-1 High Performance Motor Oil with Liquid Titanium.
The Liquid Titanium Product shows an ever so slightly lower flashpoint and VI on the MDS. Possibly because of a slight increase in G1 carrier oil with the Liquid Titanium.
Houston, TX
Scroll down in the link I posted, it is all changing to Liqui-Tek.
Note the photo:
Gene K
Decatur AL USA
Note the photo:
Got you. I finally found a MC GF-6 spec sheet. The 5W-30 is lower viscosity, higher specific gravity, lower viscosity in the cranking test and has higher VI. But the differences are seemingly minor..
Gene K
Decatur AL USA
Kendall, "The Two Thousand Mile Oil."
That's pretty good for a Nitro burning Top Fuel Car when the rods, pistons, rings and bearings only lasted 1/4 mi.
("Big Daddy" Don Garlits reference for you infants out there).
PS I know the historical context of your reference but might give the infants the wrong idea.
