I just received this oil analysis from one of my shop's customers that uses kendal 10w30 motor oil.
The had recently rebuilt this motor and had reason to recheck as they had a knocking noise which turned out to be the fuel pump clattering.
Here is the results.
Engine has 675 miles total.
Oil sampled with 175 miles on oil.
Dont know conditions engine is run under.
Has a K&N foam air filter(you'll understand in
a minute why I stated that.)
code:
WEAR METALS
copper 31
iron 22
chrom 1
alum 2
lead 72
Additives
Mo 48
ph 1100
zinc 1126
mag 46
cal 2435
CONTAMINANTS
silcon 35
OIL PROPERTIES
viscosity Cst 9.00
SAE 20wt
sulphur 76
everything else 0
