Are K&N oil filters worth the extra money$$$?
Quote:
Why anyone would consider a K&N with the Amsoil EaO and other filters is beyond me, other than if the Amsoil/Mobil 1 is not available for their vehicle..
From a lube engineer's perspective, the three most important elements in an engine's life are to use best filtration available, best lubricant and change at regular intervals..
George Morrison, STLE CLS
Quote:
Terry has stated that K&N are very good filters(in previous threads). And not just for flow. They have tested very good for filtration too. EKPolk did some particle counts on a K&N on his G35 and they came out looking good. Clearly we have learned that Amsoil Eao filters are awesome, but if you want to go to a store to buy your oil filter, K&N is one of your top choices.
Quote:
Using JUST the efficiency rating is misleading as the K&N OF will hardly ever go into bypass. Meaning capacity and life of actual filtering might miss a percentage of very small particles but trumps most OTC oil filters that cycle in and out of bypass ( with NO filtering taking place) like Bill Clinton and his lovers.
Quote:
You may want to look at the following links. They contain some info about many brands. The second link contains filtering and flow data. The information led me to try using Purolator Premium Plus filters. According to the spreadsheet they filter and flow better than the K&Ns for a whole lot less $$$.
http://www.oilfilterstudy.com/
and
http://www.oilfilterstudy.com/Grease Oil Filter Study.xls
