Originally Posted By: stchman
As I said before, if K&N air filters were so bad, then there would be hordes of tests from other manufacturers showing how bad they are.
All I hear is forum banter and one test done in 2004.
Also, where is this Chrysler TSB that states they will void engine warranty when a K&N is used on a Cummins engine?
If you don't want to believe comparative factual test data, then that's your choice. But seems you think just because no other manufactures are trying to smear the K&N brand that it's an indication that K&N filters are just as good or better than the others that the comparative test data clearly shows otherwise?
I just went back and re-read EVERY post in this thread, just to be sure I did not miss anything. I am a human and humans sometimes overlook things.
The only thing pointing to K&N air filters being bad is the Arlen Spicer test done in 2004. All the rest is forum hearsay. I have been using K&N air filters for over 10 years with no problems.
I was speaking to my friend who has K&N air filters in his 2010 Cobalt SS and his wife's 2009 CX-7. He recently did a used oil analysis from Blackstone on both their vehicles. The used oil analysis came back with a silicon of 7 for his Cobalt and 8 for her CX-7. Those are good figures. Granted, neither of their vehicles are diesels nor do either of them operate their vehicles in really dust environments, but both their is a turbo and turbos do require more amounts of air.
With all this being said I plan on doing a used oil analysis here very soon and will be paying particular attention to the silicon parameter. If the number is too high I will switch to a paper air filter and do another used oil analysis later down the road. I am not one that readily accepts other peoples results and will get my own vehicle tested.
Right on. So your "friend" operates a vehicle in conditions that one can call less than dusty and has a low silicon level in his oil sample.
Awesome. So under these seemingly ideal conditions an oiled gauze media filter keeps out the non existent dust.
Sounds like a job well done to me.
Jim Allen has forgotten more about filtration than most of us care to know. I consider him an authority on the subject and here at bitog there are a few guys I consider authorities and I try to absorb whatever I can when they do us the favour of posting their experience.
Do what you want with the wealth of info that he shares with us. I suggest taking advantage of it personally but I'm not one to waste what I consider valuable.
