Change the engine air filter and then leave it alone?
I read somewhere that when you open the air box to clean the air filter, you introduce more dirt into the engine then the filter would have done in its entire life? So should I put brand new air filter and then leave it alone for 1 year?
I'd be curious to know the source. And even beyond that, how significant this introduction is.
I have replaced the air filter on my BMW approximately every 15k miles since new, only because the factory filter is very inexpensive, about $10 for the Hengst German filter. I'm currently at 377,200 miles...even IF changing the filter introduced dust or dirt to the intake...I question how significant this is. I change the air filter with a factory Denso on my Tundra every 24k miles since new, and is currently at 383,000 miles. I'm not seeing a problem with my sample of two very high mileage cars.
I think you should just change it and then leave it be.
Unless it tears, not likely given the small pressure differential, it can only become more efficient as time passes and air with whatever debris load passes through it and loads it.
377,200 miles on a BMW 🤯 People say BMW is a money pit.
Sure beats a car payment + interest
If a BMW can make it that high my lil Jeep can too 💪
People change air filters WAY too often ... and it can be detrimental to do so.
This is an article written by one of our members (Jim Allen; writer of various automotive articles and published in many magazines and books).
A few key takeaways ...
- 90% of the particulate that a filter will pass happens in the first 10% of it's lifecycle (meaning the more often you change it, the more particulate you allow in).
- as the filter loads, it becomes much more efficient
- the average car filter may have a capacity able to hold many years worth of normal particulate loading; sometimes up to 150 grams
- etc ....
https://www.rv.com/rv/towing/the-truth-about-engine-air-filtersinternal/
Just like changing oil too often is costly, so it changing air filters. And with the added risk of inducing more dirt into the engine.
If you want to mess around with your car, give it a wash instead, and leave the air filter alone!
