Originally Posted By: Jim Allen
wsar10: The only time a K&N would produce a wickedly bad UOA is if the vehicle was run in a very dusty environment, or had been badly mauled during cleaning. As I have said, they are "adequate" but not "superior" at the air cleaning game.
That said, we have seen some not-so-hot used oil analysis with K&Ns and some ok to good ones but they all are essentially useless for comparative purposes unless the vehicle was run first for a long period in it's normal environment with a "regular" filter and then over the same period and generally same operational cycle with the K&N. You might be able to glean something by comparing the K&Ns to the universal averages for the vehicle type and brand but that would still be a yardstick when a micrometer is needed.
The fact that the K&N, and most other oiled cotton gauze filters, are at the low end of the efficiency scale cannot be disputed. Whether it matters alot in all cases is another debate.. and largely a moot one. When operated in a relatively clean environment, with "normal" oil change intervals, there is little harm done, because filration is "adequate." Some of us need/want more than "adequate" so we avoid two ply K&Ns due the lower efficiency.
Hey, you have the same access to the used oil analysis as any here... you could be the guy to collect the used oil analysis into one place.
Yeah,
just not as much time as some others here !
If I had the time I would throw together a few different threads containing used oil analysis that have info about some FAQ's or frequent discussions.
Yeah,
