I'm posting this in the ATF section since it's specific.
2007 XC90 V8 AWD 120k, not sure if the transmission has ever been serviced. It requires the infamous 3309 spec fluid.
Reputable Volvo indie shop #1 says they do a full fluid exchange using the BG machine with Valvoline Maxlife. They say they have used it for years and never had any issues. Quoted $250 including reprogram of computer if needed. This is a Volvo only shop with a solid reputation.
Reputable Volvo indie shop #2 actually told me to call their transmission specialist because this V8 AWD setup can be a PITA. Called that shop and they said they recommend a spill and fill of 8 qts of 3309 for $125.00. I got a little nervous when the guy on the phone started talking about a "22 point inspection and road test to see if there are any other problems."
My go to local general mechanic told me that they use the BG service and fluid that is 3309 compatible. He said he would not use any additives except the cleaner and there have never been any problems. About $250 for that service. He also said I could get my fluid of choice and they would do a full exchange for $100.00
Also local Volvo dealer charges $400 for a full ATF exchange. They use the BG machine, but not sure of the fluid. I'll ask tomorrow when we pick it up for an AC repair.
I've never really been torn ATF before. I can order the Mobil 3309 fluid from Amazon, or I can go get some Amsoil ATF which I have never had a issue with. I have read some of the threads here about the 3309 ATF and there is really no clear consensus.
So I'm opening this can of worms again.
