Just Ordered A New Weed Whacker
Yes i have the echo, I immediately modified it for best performance.
The carb is plugged, you only need to access the high flow adjustment screw, as the idle is fine. Ditch the exhaust screen too.
there are videos on the modification out there.
Yes I like it , but never used in stock config
If you ordered it from Home Depot, it's going to need the air to fuel ratio adjusted. The receiving area of Home Depot is littered with returned Echo string trimmers because the average consumer has no clue how to set air/fuel ratio.
Look on YT for the procedure - if I remember correctly you have to pull out a brass plug to get access to the screw. It makes a big difference in how the engine runs, highly recommended.
Another update: the air/fuel ratio is non-adjustable on this carburetor; you have to remove a limiter cap so that means buying a special tool. They can possibly be removed by yanking w/pliers but not sure. It runs fine, so no adjustment needed at this time. Also, the motor has "assembled in USA" if that matters to anyone else.
Here is the procedure for adjusting the carb. fuel mixture on an ECHO 225.
The tool is $7.19 on Amazon.
What does this have to do with the depot? I got my srm2620 from the home depot right off the shelf but my edger shipped straight from echo to me via home depot
Here's the carburetor for the SRM-225.
In this drawing, the low speed mixture needle is not shown, but I have the passageway marked by the red arrow.
Reference #11 is the plastic plug to be removed for gaining access to the low speed mixture needle.
The special tool (Echo 91157) has a threaded tip for screwing into the plastic plug.
In this drawing, the 1st red arrow points to where the high speed mixture needle.
The 2nd red arrow points to the opening where you insert your screwdriver for accessing the high speed mixture needle.
The High speed screw is the main one to be adjusted, unless some obvious issue, messing with idle fuel not necessary.
adjust the high speed with warm motor, at full throttle, till motor runs its cleanest and fastest.
mine starts cold at full choke with a couple bulb squeeses, and 3 to 4 pulls, soon as motor starts take the choke down a 1/4 or half inch for 20 seconds then choke off.
Ive had mine for a few years , and yeah take the exhaust off an remove screen, before adjusting fueling.
Ive had mine for a few years , and yeah take the exhaust off a remove screen, before adjusting fueling.
Actually no. This is very close to the proper procedure.
Ensure the spark arrestee is clean and present ..l, do not permanently remove the spark arrestor.
Do this and as you are turning the high-speed jet in and it runs faster and faster, you will get to a point where it is too lean and slows down again. What you want to do is go back it out back to the fastest then make then continue making it ever so slightly more rich. You just want to hear the RPM drop a tiny bit. Your target is very slightly rich of peak.
If you run it at absolute peak it will run to hot and not last many years
Like I said , had mine for years runs great , half turn at most.
if dont remove screen it will clog, but do what you want
I have one and it's never given me any problems. I removed the spark arrestor screen (was nasty but not clogged) and the limiter cap on the carb high speed jet to make some slight adjustments. It didn't "need" any adjustments, I just wanted to tinker. Ended up setting the high speed jet back to about where it was from the factory.
