Just Ordered A New Weed Whacker
So, basically screw in the high speed screw (the one near the primer bulb) after removing the limiter cap until it gets lean and runs its fastest, then screw it back out to richen the mixture until the rpms slow a little? Thanks for all the help. The limiter cap tool is supposed to be here from Amazon (I got the cheap $7 one) so I'll adjust it tomorrow.
You get it right at the point, the rpm increase with solid run, then you stop , doesnt take alot of movement. Its been so long since I did mine, my memory not perfect.
The vid in the thread, there are better ones that id look for
