Just how hot do lawn mowers get?!
Just wondering if anyone else has taken the time out of boredom and use an infrared temp gun on their lawnmower to see how hot they actually got during usage?
Fun topic 😜
I have done this, I have aimed the gun at:
1) The Oil Filter
2) By the Drain plug on the outside of the Engine
3) Down the oil fill hole on a Briggs 6 HP Engine
Here is where it gets interesting, for my Riding Mower I need to get a Temperature Device with a Probe, because I am thinking my temps may be 20 to 30 degrees higher.
Interesting side note. Years ago I had a Kawasaki 23 hp air cooled rider. It would run on for quite a bit after mowing. I would have to run it at fast idle for 3 minutes to cool it down enough to prevent it. Heat radiated off the engine like a stove. This machine was using conventional oil at the time. I switched to synthetic and it cooled down tremendously. A 30 second cool down was all that was needed with syn. And the radiant heat was noticeably cooler. I wish I had known what the temps were. I had also read that Briggs and Stratton demonstrated a 10 degree cooler running motor on theirs with syn.
So I've been tossing around the idea of swapping out say for example "oil X" with "oil Y" just to see if there's much of a difference in temp between the two oils 🤷
Air cooled engines are mostly very tough, simple designs engineered to handle higher running temperatures. The most important thing is keeping their cooling fins, air ducts around the cooling fins clear/clean and the oil full. Thermal shock isn't great for them. Better to idle them a couple of minutes before going full throttle, high load and idling a minute before shutdown to limit soaring temperatures due to heat soak after shut down. Doing that and keeping the air filter in good condition is ideal.
Some lawnmowers get real hot. 🤣
