Since my previous cooling system post has gone south, I thought I'd redeem myself and post another question.
It's time for fluid maintenance on my John Deere 1025 subCUT tractor with a Yanmar diesel NA engine. Of course the owners manual recommends John Deere products including Cool-Gard II coolant. But the local JD dealer wants $28.22 for a 4L jug of their pre-mix, and a local distributor has Prestone Command HD premix on sale for $8.99 a 4L jug.
Is the John Deere coolant 3 times better?
The owners manual says if JD products are not available then use a "coolant intended for use with heavy duty diesel engines," and they want nitrite free, "providing cylinder liner cavitation protection according to JD Cavitation Test Method or a fleet run study run at or above 60% load capacity, protects cooling system metal (cast iron, aluminum alloys, and copper alloys such as brass) from corrosion."
I have no idea what the last bunch of stuff means.
If they want cavitation protection then the Yanmar engine must have wet cylinder liners, but I can't actually find that information anywhere. I've only found vague references to European standards wanting no nitrites but again I have no idea what this really means.
Any coolant experts out there that can clarify all this? Thanks!
