Greetings everyone.
Last year, the coolant overflow cap on the expansion bottle on my '89 Jeep Cherokee blew off on the highway without warning (cheap plastic cap threads). Well, the coolant leaked down the fender/firewall and gave no warning until the head gasket went. I have changed the head gasket, but still have low compression in cylinders 3 & 4. Actually, at first, I had no compression in both cylinders until I let it run for 15-20 minutes and then the compression went up to 60 PSI. This is a 4.0L with 90K miles.
A couple months ago, for about a week, the compression magically went back up to 100-110psi in both cylinders! I thought it was fixed and that the rings were just gunked from coolant entering those cylinders (the truck sat with coolant in both for a couple of weeks). Unfortunately, after that week, it went back to 60-65 just as quickly as it went up. It does currently have a slight skip, as cylinder 3 & 4 are opposite in the firing order, but it doesn't run too bad. However, every once in a while, the idle will smooth out (with compression readings jumping up to 75-80PSI) and then after a few minutes it will go back to 60-65 PSI in those two cylinders. It burns none/very little oil and there has been absolutely no smoke on cold start (even on the coldest of days) running Valvoline 5w30 conventional.
I currently have a low milage replacement motor to toss in, but I am really interested in trying out the AutoRX to see if it can clear up the ring packs in this engine. If it doesn't work, then nothing is lost as I have the other engine. I placed my AutoRX order today and hope to receive 'em in a few days (I'm going to try it in my '92 2.5L Wrangler trail rig too) and then I will do a baseline compression test and then change the oil with AutoRX and cheap conventional 10w30 (probably SuperTech). I'm a snake oil skeptic, but I've been on here for a few years and know that many have had good results from AutoRX. The condition of my XJ's 4.0L is probably on the more severe side for any additive to try and fix, but hopefully, I'll be able to be one of the "testimonials" on their website.
Anyone here have any compression test results from using AutoRX? I feel pretty optimistic that AutoRX will be able to spruce these rings up.
I look forward to sharing my results.
Talk soon.
Talk soon.
