So we have a Jacuzzi (or similar) jetted tub in bathroom. Wife uses it mainly for plain baths. But recently tried the jets and all we hear is a hum.
Reading up on it it sounds like the impeller is stuck.
They say to remove the access panels and there is a space to stick a flat blade screwdriver in end of the pump and turn the shaft.
I have no access panels. Went into the crawl space and someone did cut a 5"x5" hole around the drain. But the drain is in the middle of a long side. The pump I think is at one of the two ends.
So can I use water or water and a chemical in the water to free up the impeller? Suggestions for a chemical?
Hot water?
Hot water?
