Good evening all.
So I am about to help a nabour putting on his winter tyres. Unfortunately the jacking points down by the panel are rusted out and too soft to lift at.
At the front I can lift at the subframe. At the rear the only place I can see is the lower control arm under the spring/spring bowl.
Will it be okay to jack up the car on the lower controlarms under the spring on the rear axle, or will it hurt/bend anything ?
Thanks in advance all.
Søren
Søren
