For normally spec'ed "Lifetime" fluid fills it is also a Lifetime fluid.
For severe duty applications it can be changed at twice the interval the OE recommends.
For normal applications they ask you to refer to their online guide for application specific intervals. It has been my experience that it's usually double what the OE says it should be changed at. I did this in my journey and it was still bright red and clean at this interval.
Quote
What are the change intervals for AMSOIL Multi-Vehicle Synthetic Automatic Transmission Fluid and AMSOIL Fuel Efficient Synthetic Automatic Transmission Fluid?
Answer: When using it is recommended you follow your vehicle manufacturer's normal-service drain interval and double the recommended drain interval during conditions of severe-service. Check the AMSOIL
Online Product Application Guide for detailed recommendations.
Source:
https://www.amsoil.com/frequent.aspx
You can also contact them here and they will give you specific information for your application as they did for me with my Journey and Highlander.
https://www.amsoil.com/techservices.aspx
Here is what they sent me with regards to my Highlander:
Quote
AMSOIL ATL (and OTL) meets all Toyota type WS fluid requirements and is recommended. I do not have test results for the OE Toyota fluid.
Toyota says the WSS fluid is a "Lifetime" fill, but that is under "Normal" service conditions, and is true for the OTL as well as the ATL fluid.
Under Severe Service conditions, they say the fluid should be changed at 60,000 miles or 72 months, whichever comes first. Based on this the AMSOIL ATL can be used for twice as long ----, up to 120,000 miles or 144 months.
Thank you for contacting us. If you have further comments or concerns, please contact us again.
Byron Selbrede
Technical Services
AMSOIL INC.
ADDRESS: 1 AMSOIL Center, Superior, WI 54880
E-MAIL:
[email protected]
PHONE: 715-392-7101
FAX: 715-399-6531
