It's alive, again!
The Garden State
My 9 year old Troy-Bilt power washer that hadn't been used for 6 years was only putting out a light water spray. I checked to make sure there were no blockages in the lines, there were none. The B&S engine and frame are great. It had a FAIP MTPV90736 pump, no longer made. I bought a new AR pump for $111, delivered, now my unit works like new
. Cheaper than buying a new power washer for ~$300.
Whimsey
I was in this same boat last year, I ordered a new B&S pump for my powerwasher that was actually better quality than the one that came on it.. Fyi its a good idea to use some pump saver now and again, I always condition my pump every fall before storage.
Most definitely will use pump saver from now on. Any recommended OCI for the pump oil? I know they don't take much. A sticker on the pump said Weight 90. I purchased some Briggs pump oil years ago and never used it. It just says for all power washer pumps and it's full synthetic.
Whimsey
Originally Posted By: JTK
Nice! Did that new pump bolt right up with no fuss?
Just had to get longer bolts, no big deal. Other than that it fit like a charm
. One of the mounting arms of the AR pump even has a large cut out in it so I can drain the oil easily from underneath. It feels good to extend the life of older OPE and save money at the same time
Whimsey
