I spent about three solid hours on it today stripping things down to get to the head bolts. The directions are pretty lackadaisical and what was a simple remove two cap screws and shield, then muffler turns into rather difficult access to the two exhaust manifold studs on the bottom of the head.
I could see one and got some spray on it. Later figured out there was a bottom heat shield under the muffler that needed to come out and then I could get to the one stud and see the other. The one came out easy but the other is hard to get to directly. I finally jacked the rear end way up in the air and can crawl under it to see it good but still need some sort of wobbly extension to get to it. I'll wait until tomorrow. Then I can get to the head bolts.
It would have been as easy to take the whole motor out.
The darker fins were packed solid with fuzz. Around the front was mostly dirt. The bottom of the motor is covered in oil from 23 years of a slow leak. When I get the muffler off I'll hit it with some diesel and dawn then the power wash.
