Originally Posted By: The Critic
I think the newer paints are fairly good.
Surely catalyized lacquer and modern acrylic paints are superior in many regards to the old nitrocellulose lacquers. Clear coat helps, but is generally a little on the soft side (for a reason). I am only aware of two car manufacturers that use self-healing clear coat, MB and Toyota.
Quote:
Most cars on the road are never waxed and the paint still looks great after 7-10 years, at least out here.
You need to touch paint to tell its condition. Wax or polymer sealants prevent microscopic particles from embedding themselves into the finish. Closely examine a horizontal surface, hood, roof, boot, of a vehicle and see tiny specs that often cause tiny rust stains on the finish. Those are metal particles that embed themselves over time in the finish and that cause micro pitting. With a protective wax or polymer layer, such contaminants can much more readily washed off or removed with a paint cleaner or clay. Seeing may mean believing, but when it comes to paint, you have to touch it to gauge its cleanliness and condition. [/quote]
Quote:
Also, what good is it to wax twice-a-year?
When I used wax, I waxed as soon as the water wouldn't bead off the pain. Depending on the weather, a coat of wax would last from a month to four months. The polymer coating I have been using for over a decade lasts about 10 months.
Quote:
Most waxes and sealants last 6-8 weeks, so for most of the year, your car is without protection anyway.
So you can't wax more often or you won't use a longer lasting product? Odd.
Quote:
Unless we can compare a car that has been waxed religiously on a monthly basis versus one that has not, it is difficult to draw any conclusions.
Your only a bit older than my car! You aren't old enough to have seen a car finish age over a long period.
