Is Valvolineâ„¢ ZEREXâ„¢ G-05â„¢ Antifreeze / Coolant compatabile with the MercedW220?
GON
$100 Site Donor 2024
Steilacoom, WA
Is Valvoline Zerex G-05 ok for use in the S class 2000-2006 Mercedes W220s? Valvoline website indicates it is but, I have not found any user testimonies. If it is ok, can it be mixed with the blue (pentosin) from the factory, or does it require a flush?
ZEREXâ„¢ G-05â„¢ is the automaker approved original chemistry used in newer Ford, Chrysler and Mercedes-Benz automotive and diesel engines. Its Hybrid Organic Acid Technology (HOAT) chemistry combines the best of conventional and organic acid-based chemistry to provide the ultimate protection against rust and corrosion. ZEREX G-05 antifreeze/coolant uses the highest quality virgin ethylene glycol for freeze and boilover protection and a hybrid organic acid corrosion inhibitor package to protect your engines from liner pitting and corrosion.
G-05 is totally fine with your W220, Mercedes is back specing G-48 for all their cars now.
Even though it's back speced in my 2002 CLK430 to use G48, I'm still running G-05 in mine and draining and filling the radiator only every 3 years, always comes out spotless and I've had no cooling issues
Originally Posted by Building3
What exactly is G-48 coolant? Is it OAT or a Dex-Cool or something else. Are G-05 and G-48 compatible? Thanks.
G-48 is the new blue-colored Mercedes service coolant, it's also used by BMW/Mini. The main difference is the organic acid, it uses 2-EHA(hexanoic acid) versus G-05's sodium benzoate(benzoic acid). They are compatible.
Mercedes is now using G-40, which is the same as VW's G12++ coolant. I dunno if G-40 and G-48 can be mixed.
Do you have any clue if G40 uses 2-eha?
Valvoline info for Zerex G48 says it's a HOAT. The word "Hybrid" is even spelled out. Check the links I posted earlier. PI sheet from previously posted link shows 250 ppm Si typical.
Zerex G40 is a Si-OAT per Valvoline. No amines per the PI sheet, and 200 ppm Si typical.
https://www.valvoline.com/our-products/heavy-duty/zerex-g-40
FWIW I don't see 2-EHA on the English SDS. I do see Ethanediol listed.
Thanks.
I'm finding conflicting answers online on wether VW's G-XX coolants have 2-Eha or not.
Some sources say they do, others say that they do not.
I've Emailed Glysantin to see if they can provide me with an answer.
Originally Posted by Nyogtha
The SDS for Zerex G48 does show sodium 2-ethyl hexanoate as well as ethanediol.
I can see both G40 and G48 contain Ethanediol and Benzoate, but i can't see 2-Eha mentioned anywhere.
