GON
$100 Site Donor 2024
Is Valvoline Zerex G-05 ok for use in the S class 2000-2006 Mercedes W220s? Valvoline website indicates it is but, I have not found any user testimonies. If it is ok, can it be mixed with the blue (pentosin) from the factory, or does it require a flush?
ZEREXâ„¢ G-05â„¢ is the automaker approved original chemistry used in newer Ford, Chrysler and Mercedes-Benz automotive and diesel engines. Its Hybrid Organic Acid Technology (HOAT) chemistry combines the best of conventional and organic acid-based chemistry to provide the ultimate protection against rust and corrosion. ZEREX G-05 antifreeze/coolant uses the highest quality virgin ethylene glycol for freeze and boilover protection and a hybrid organic acid corrosion inhibitor package to protect your engines from liner pitting and corrosion.
