Is there anything special about these stubby B&S filters?
IN
Other than being guaranteed to fit, is there any other benefit to paying 14 dollars for these? I always replace them with a cheap ST3614 ($3.84)
They are absolutely nothing special and are most certainly overpriced. They are shaped to fit the application and that's about all that would make them a consideration.
In my modest opinion, they're way overpriced and not worth the effort to purchase.
Only if you want it to be black instead of white like a SuperTech will be.
I've pointed a non contact thermometer at the oil filter on my mower after cutting the entire yard nonstop, and it's incredible how hot it ISN'T. I think their claims of designed around higher temps are doo-doo.
Nothing special. There is a C&P in YouTube for a John Deere that's internally exactly the same as a Fram.
I have an application where the space is a consideration, so I am buying this one:
https://www.amazon.com/Hipa-951-12690-751-12690-Craftsman-Troy-Bilt/dp/B0DMV9T99T/
Because I can't go any taller and it's only 2" tall.
No real info on Hipa brand filters, but their other stuff gets good reviews.
The competing NAPA filter is $20. Totally not worth it.
It's a lot like the one pictures in the TY video
How to change oil and oil filter for lawn mower Craftsman 1000​
by Keral Cowboy
Not directly linking because of potential forum rule violations.
When you see it the oil filter is pointing to a rear tire. There is just not a lot of clearance there to fit in a much taller oil filter.
video links violate rules?
If there is a curse word said in the video, yes. I'm not sure about the comments. So, unless you have the time to listen to every word in the video before doing a direct link, post a reference to the video instead of a link. I suspect that the specific video I am referencing would be OK, but I am at work and don't have headphones to make sure. I'm not the only person here no longer directly posting or linking videos. Sometimes I do post screen shots like this:
As you can see installed, there is not a lot of extra room there before the filter would hit the tire, and the filter points right at the tire:
So it's a matter if you feel comfortable closing that gap with a taller oil filter just to save a small amount of money and maybe purchase locally.
I’ve almost said bad words in my threads but stopped myself. If we’re all adults I don’t really see the harm in it? But oh well not my decision
