both type IV and JWS 3309 are conventional fluids....,
as is Pennzoil A/M/M......, only the Penz has a ton of VII'S.... to lower the pur point....,
I used the Pennz in my Rav , for almost a year..., in the winter everything was fine, but as the weather warmed up, The trans was shifting very harshly, and a high pitched whine started....., I called Penz tech , and spoke to someone who said it was not compatable with JWS3309....., and certin AISIN WARNER auto transmission..., Penz, is not compatible with the friction material in the AISIN WARNER trans........, the tech todl me to fluch the trans with a JWS 3309 approved fluid....,
I flushed 12 litres of mobil 3309 through the trans.....,
the shifts are smooth again, and the noise is gone......,
If you have an AISIN WARNER trans be very weary what you put into it........., it easy to tell. Look into your manual...
If it says to use TypeIV or Jws3309 it IS an AW trans.
if it says to use typeIV or DEXIII in emergencies then it is most likly not AW.
Dont forget to drop the tans pan and clean it , if you have more than 75,000miles. ..... mine had lots of metal material on the magnets.
cheers
Also you can not rebuild AW auto trans , you have to buy a new one......$$$$$$$$$$, according to 4 dealerships, and 6 trans shops in my area.
