Seafoam won’t do anything and you won’t notice a difference if you don’t have a problem.
If you do have a problem it works great. I used it in a four stroke outboard that was not used for 5 years. put fresh gas in it and tried running it and it just wows running real rough even after running a couple of gallons of gas through, put sea foam in it and after several minutes it smooth right out.
I put it in a carb fuel bowl and watched the crud melt right off.
I use it in all my OPE when storing and through the first tank for the season and always with Top Tier.
But I do like the smell of MMO, and use that more as a cutting fluid and for cleaning up tools.
