What about high consumption on a new engine (Nissan QR25DE) of 1QT/1500 miles?
How many miles on the new engine? Some take a while to settle down. I've been pretty lucky, but I've heard of people using that amount of oil for up to 15,000 miles.
It only got worse with age.
Not true. If you plot oil consumption vs. miles or hours on the engine, the curve has a "minimum" somewhere near the mid-life of the engine. New engines burn significant amounts of oil until the rings seat, and consumption will gradually drop. Most engines will be at their lowest oil consumption by 10,000 miles, but some take a bit longer to bottom out. Then they stay there a long time unless they're damaged. ALL piston engines burn SOME oil, even if you can't notice it on the dipstick between oil changes. The engine may stay at extremely low oil consumption for a LONG time (100k miles or more in some cases) before consumption inches back up to where it was when the engine was brand new and the rings not yet seated fully.
Different engines drop to different levels of minimum consumption. As I mentioned in another post, some of it is related to simple engine dimensions. Engines with big-bore cylinders (and 8, 10, or 12 cylinders instead of 4 or 6) will burn more oil just because more cylinder wall (with a thin film of oil coating it) gets exposed to combustion gasses on every turn of the crank. Ya canna change the laws O' physics.
