I'm going to be servicing a 2006 6.0 Powerstroke trans soon. Is Maxlife ok to use for a few spill and fills?
And which ATF are you using in your BMW per your signature...?I've got the same transmission in the BMW and my mechanic said to stick to OEM fluids for this - even though maxlife says it's compatible on the bottle.
Mercon SP is already cheaper than ZF LifeGuard 6 so I would personally not take the chance
https://www.rockauto.com/en/moreinfo.php?pk=611298&cc=0&pt=11387&jsn=4
+1 for Valvoline Extended Protection ATF. It has a higher quality additive package than MaxLife. That doesn't mean that MaxLife is a bad product by any means.Another alternative that's been discussed lately is Valvoline Extended Protection ATF which is also suitable for Mercon SP applications.
I'll give you my two cents: since it's a 2006, and the transmission sits behind a torque Diesel engine, I would go with Castrol TranSynd 668. I've used it in two ZF 8HP transmissions and two 6-speed Hyundai transmissions with great results. TES 668 fluids are formulated with better materials because they are commercial grade fluids. If it was my truck, I would use a TES 668 fluids. The Castrol TranSynd 668 is the easiest to find. Most NAPA stores have it on the shelves or they can get it for you the same or next they. Amazon sells a 3-gallon box for $135.I'm going to be servicing a 2006 6.0 Powerstroke trans soon. Is Maxlife ok to use for a few spill and fills?
Mercon SP is obsolete from Ford. When we try to order it, the order defaults to LV.This is always a debate. I fall in the camp that SP was superceded by LV, but others swear SP is a special animal unto itself.
@bdcardinal what does your service dept do on apps that would have initially been SP? Do you even carry it? I've been told most Ford dealers don't stock or use SP, but that's anecdotal
It's available from Motorcraft: https://www.motorcraft.com/us/en_us.../mercon-sp-automatic-transmission-fluids.htmlMercon SP is obsolete from Ford. When we try to order it, the order defaults to LV.
It's not hard to make, because the additive package used in Valvoline EP ATF, Mobil 1 LV ATF HP, and all TES 668 fluids, including Castrol Transynd 668, is the same, and covers Mercon SP. The only difference is base oil mix and viscosity.
Given the Mercon SP specs, Valvoline EP ATF will cover it just fine. So will Valvoline MaxLife, however, I would opt for EP, as it's the better fluid.
The good thing is that the OP has several good options to choose from.
Great info here as I am going to be replacing solenoids on my 260k mile ZF 6HP soon and would prefer to use fluid I can get locally. Rockauto has Lifeguard 6 for a decent price but really would prefer to not have to order fluid and wait for it.It's available from Motorcraft: https://www.motorcraft.com/us/en_us.../mercon-sp-automatic-transmission-fluids.html
