Is there a synthetic Mercon SP?
CA, USA
I can not find a compatable synthetic Mercon SP for my Ford 6.0 Powerstroke. Ford makes it very clear that only Mercon SP can be used or there can be damage. I see alot of synthetics for Mercon and Mercon V but not for Mercon SP.
I believe that the MC (and comparable ConnocoPhillips branded oil) is a semi synthetic blend. I have run thicker oil in the 5R110 without problem. The SP is just a thiner oil but has comparable FM characteristics to MV I think. Someone with more formulation knowledge would be good to ask. MolaKule might have an SP ATF?
