Originally Posted by edyvw
Originally Posted by TiGeo
Pardon the ignorance - but still not getting it. Help me understand. I get Noack - lower is better or less "evaporation" - correct? So over 10 is worse than 9 like the big-name Euro oils (Castrol/Mobil 1). Check. Walk me through KV100 and HTHS and why 14/3.5 is a problem?
Walk you through? Hundreds of threads here about it.
But, there are two ways to get high HTHS, which is what REALLY matters. Manufacturer could go cheap base stock, high KV100, or more expensive or expensive base and lower KV100. You really do not want too high of KV100. You can google why HTHS is important, numerous explanations, some more complex some more simplistic. But, all European approvals are not interested in grade (except VW504.00/507.00 which limits oils to 0/5W30 and min. HTHS 3.5) but HTHS of min. 3.5 (let's talk just approvals based on ACEA A3/B3 B4, C3). VW502.00 approval is based on HTHS, not KV100 and with that grade. They want HTHS of 3.5. Will that be 0W30 5W30, 0W40 or 5W40 and even 10W40, is irrelevant to them. So, high KV100, low HTHS indicates not such good base stock, and Noack also confirms that in your LM.
Now, that oil is fine in your vehicle. However, why getting that when I can get for $22 5qt jug of superior oil in Wal Mart? Would I put that oil in my Tiguan or BMW? Sure! Eliminate choices like Mobil 1 0W40, Castrol Edge 0W30/40, Pennzoil Platinum Euro 5W40, Pentosin HP 5W30/40, Motul X-Clean or x-Cess, etc. and yeah, I will put it in.
Does it bother me? No. But, you put it here, which means you expect answer. So, not all answers are going to be what you expect: approval.
Ok, so Group 3 base stock vs. the more Group 4 is really all this is about - got it. No, I don't need anyone's approval for what oil I use, but I do like to understand it and will be doing some reading up on HTHS to get more familiar with it. The idea of oil superiority based on this stuff has no metric, to me, in the real-world i.e. will running XYZ oil cause my car to run to the desired mileage/time or the better question, will running XYZ oil cause my car to NOT run to the desired mileage/time? Changing oil at 5-7.5K, will it really matter if I use Mobil 1 0W40 or LM XYZ 5W40 with worse HTHS? Nobody f'ing knows but it's sure a great debate on BITOG!
