I have a GC 190 6.0 Honda Power Pressure Washer that i bought not to long ago. I had put 10w30 Havoline PCMO. I did the recomended drain that the manuel recommends whichs is change the oil after 5 hours of use. When i changed it( engine cold) i notice that the oil had this brown metallic look. It had little fine metal particles floating in the oil. So, then i proceeded to give it a quick flush with the craftman's 30w oil that came along with the power washer. I did some cleaning for about 15 minutes and then flush it with the enging hot this time. Man, it came out the same as the Havoline oil and maybe a little darker. Is this normal? I know that it goes through the breakin period but should the oil be that color, with small particle of metal floating around?
I then put some Mobil 1 Extended Performance 10w30 to use from there on.
