I recently picked up a slightly used Shark cold water pressure washer from a buddy. The unit has a 13HP Honda 390GX single cylinder air cooled engine and a Legacy Triplex pump.
I changed the motor oil and used Chevron 10W30 (have lots of it on the shelf).
The Legacy pump specifies 30W non detergent oil. I picked up some Shell 30ND oil at Advanced Auto today (the only brand they had). This is 30 weight API SB rated non detergent oil. I was curious why they specify non detergent oil in the pump. Will a detergent 30W hurt anything? There are much better 30W oils on the shelf (Chevron, Havoline, Castrol etc.) but they are all detergent oils. Why is non detergent oil necessary for the pump? Thanks.
