It may seem to be "running great" and be all healthy from what you can tell, but how do you know it couldn't have been better than it is if xW-30 was used? Did you do some compression and cylinder leak down baseline tests, and some dyno rwhp baselines after break-in? In order to determine a difference in the real world it would take a multi-million dollar controlled test program. That's where controlled lab wear tests come in as mentioned earlier.
Sure, if the owner doesn't detect any "oil use" (lots of subjectively monitoring oil level), and the engine still "runs strong" from behind the wheel, then they believe no wear must be happening. But all engines wear, and the wear rate is caused by many factors - too low HTHS for the conditions is one of them.
Are you using low HTHS in your track car? Why not if it doesn't really matter with respect to wear? Would you put thicker oil in that Focus for track use? If not, it may not "blow-up", but it's definately going to wear faster and more.
Sure, xW-20 will work fine (with some possible increased wear) in the streets od daily driving, but even on the streets xW-30 is going to give added wear protection in all possible driving conditions. That's my whole point, I like and choose headroom.
