As far as I understand it, ACEA certification is on the honor system via self-certification. That means the oilmaker produces test data that shows the oil meets the ACEA test requirements, but the data is not verified by in-house ACEA or independent testing. That's pretty much the same as with the API, I believe. This helps to explain why many carmakers continue to have and to develop their own oil specs.
