And PAG ones seem to be better.
Another thing to consider would be the NLGI grade of the caliper pin grease (some pairs may not be particularly happy with a higher one) .
PAG ones tend to be grade 2 while silicone ones can vary from grade 1 (MOLYKOTE® G-807) ...to NLGI grade 3-4 (MOLYKOTE® 111 , Motorcraft XG-3-A , 3M etc.)
Great thread with a lot of info :
I've spent way, way, way, too much time (no, seriously, way too much!) researching this to not share it and hopefully save others the frustration, there's no shortage of bad info out there, including annoyingly from the OEM's themselves. This is primarily focused on brake part lubrication but does include some odds and ends and is far from complete or definitive, if you can believe that!
Manufacturer is listed first if known / Followed by other sources of the same product (Part Number) - Color of the product (NOT the packaging), Description with known info, absence of info does not...
