- Joined
- Sep 26, 2010
- Messages
- 9,835
Originally Posted By: 2010_FX4
Originally Posted By: Patman
Originally Posted By: Nick R
Oil is thicker when colder. So theoretically, by running a lower thermostat (Especially with an oil-water cooler) you could get a 30wt oil out of a 20wt.
Nick is correct. To further illustrate it, take your typical 5w20 and it's got a viscosity of around 8.5 cst at 100c (212F) A typical 5w30 will have a viscosity of around 10.5 cst at 100c. But if you've got an engine which has an oil cooler and it keeps that oil at a typical operating temperature of around 195F instead, your 5w20 oil will probably end up having an operating viscosity of roughly 10.5 to 11 cst.
So at what temp does a 5W-20 become 5, 10, or 15 and is there a chart or calculation that shows this?
Also, would this situation not negate any benefits for the reasons that a 5W-20 was specified in the first place? If I am running a 30 grade all the time (when running 20 grade), in the same context would I be running a 40 grade (when running 30)? Seems the "CAFE" benefits would be lost...
I will preface this by saying I am no expert and I am here to learn as much as the next chap. However, after researching this a bit, I am not sure that I can agree that a 20 grade oil is "operating" in a 30 grade when running at a cooler temperature. There are many resources and test data available on the web (not all of them may be as accurate as others), but I could not find an example of 20 performing as a 30 in any of the data.
Here is a chart showing oil viscosity versus temperature (according to the report, these are various brands of oils):
As seen here, even at 160F a 20 grade oil is still operating in a 20 grade, conversely, at 210F both 20 and 30 grade are operating between 10 and 12-13 (most of the
Here is a link to the entire report:
Oil Viscosity
Please share your thoughts about this as I am eager to learn and understand this.
Oil Viscosity
