quote:
Originally posted by VaderSS:
quote:
The last model Chevy Caprice police package came with 4L60E transmissions and LT1 motors. The instrument cluster had a vacuum flourescent digital speedometer, withanalog tach , fuel, temp, and oil pressure.
No tach, and had a volt meter, but otherwise correct. 94-96 Caprices, 9C1 or otherwise, never came with a tach.
quote:
Bypassing the heated throttle body (Loop the coolant hoses) sure does gain power. I almost cry that I can't pull that stunt here, as my throttle body would ice up.
We have members in Alaska that have done the TB bypass. Not ONE instance of icing. The TB serves as a heat sink to condense steam from the heads, not as a deicer. It is of most use in EXTREMELY hot climates, not cold ones.
The 94-96 Chevy Caprice ordered for Government (FBI, CIA, DEA, DOD, etc) and for police departments had an unusual instrument cluster:
A large "calibrated" vacuum flourescent speedo, flanked by an analog tach. Also had the oil pressure, volts, coolant temp, and fuel on the side.
This was NOT available to the general public, though I suppose if you had such a car you could always try to order a "police" instrument cluster from GM.
My friend in Salt Lake City with the retired Utah Highway Patrol 1996 Chevy Caprice has this instrument cluster.
He got a muffler shop to put on custom stainless steel pipes that go through Borla Oval racing mufflers. The pipes exit in front of the rear wheels. When you hear that beast on an on-ramp you KNOW it's a serious machine.
The 94-95 Chevy Impala SS had oil pressure, volts, coolant temp, fuel, and a speedo: no tach, and a wimpy column shifter.
The 96 Chevy Impala SS had a floor shifter. The instrument cluster finally had a tach, but they deleted the volts and oil pressure gauge.
A local with a 2001 Chevy Silverado and Vortec 4.8 litre V8 tried to bypass the heated throttle body. His gas pedal froze at -30 C / -22 F.
So unless I move to a much nicer climate, I'll leave the coolant pipes hooked up to my throttle body.
BTW: on my 5.3 litre Vortec, the steam relief pipes from the aluminum heads are piped to the surge tank, not the throttle body.
Jerry
