quote:
Originally posted by Blue99:
Patman,
I’m going to back off & agree with you that GC should easily beat M1 5W-30 in cold crank rating.
After some checking, the GC ASTM 5293 rating listed in this thread is most likely the 0W grade max viscosity of 6200 and not the actual GC cold crank number. With a -63C pour point, GC should be in the 3-4K range.
I frequently refer to the Castrol SLX 0W-30 (German) Data Sheet, but of course, cold crank per ASTM 5293 is not listed. It would be helpful if someone could obtain the actual -35C value for us.
I still think M1 5W-30, with a cold crank of 3600 cP @ -30C and a -45C pour point, will also meet the 0W rating of max 6200 cP @ -35C. From looking at a number of ASTM 5293 cold crank ratings, the viscosity curve hits a wall & takes off at about 10 degrees short of pour point. The 0W rating of -35C is just 10 degrees from the M1 5W-30 pour point of -45C.
I can't find the cold cranking viscosities of M1 5W-30, but using the calculator here -
http://www.geocities.com/CapeCanaveral/3655/VI.html
I get a viscosity 6065 cSt for M1 5W-30 @ -30C and 10701 cSt for the same oil @ -35C
Using the Castrol datasheet here -
http://www.castrol.com/liveassets/b...local_assets/downloads/p,q/pds_syntec_usa.pdf
It has the cold cranking viscosity listed as 6200 @ -35C and using the calculator above it has an actual viscosity of 6766 @ -30C and 11698 cSt at -35C
As far as the actual viscosities, not the cold cranking numbers, they don't look a lot different do they...
edit: as far as the Castrol datasheet, I believe this to be the correct one since it lists the 0W-30 as having a 100C viscosity of 12.1 cSt and claims it "Exceeds European ACEA: A3, B3, B4; VW 502 00, 505 00, 503 01; MB 229.1, 229.3; BMW LL-01", etc.
The old Group III 0W-30 wasn't that thick and didn't meet those specifications iirc...
[ January 19, 2005, 03:03 PM: Message edited by: jsharp ]
