Interesting State of CA Report For BP Oil Filters (2008)
I read most of the report, what I came away with was that the filters do extend the oil life on the big diesels, they can absorb the cost of the of the filters and elements and pay for themselves with saved oil, diesel oil is high tbn and it lasts. The small bypasses for gas vehicles couldn't absorb the cost of the filters and elements because the oil doesn't last in a passenger car like the bigger rigs, the only way it would pay for itself is if the cost of the filter and elements was low and adding enough top up oil to keep the tbn up, an old Frantz and a roll of toilet paper wasn't part of the research. :)
The state only used Fram synthetic media X2 spin on filters for the gas engines in this test. They did reference a federal test utilizing BP filters on Tahoes that averaged 33k mi/yr. Here is the reference:
" Additionally, staff identified several reports on other HE oil filter studies. The Idaho National Laboratory (INL) had conducted a three-year study on diesel buses and gasoline-powered Chevrolet Tahoes. Seventeen vehicles were fitted with puraDYN filters. During the testing, more than 980,000 miles were run on the buses and more than 300,000 miles on the Tahoes. Oil condition was monitored by collecting 240 samples from the vehicles. The filters extended the oil drain intervals, reducing oil purchases and waste oil generation by nearly 90 percent. The buses accumulated almost 30,000 miles per year. Installation of HE filters on the buses had a positive payback at 72,000 miles, or slightly less than two-and-a-half years. For the Tahoes, which traveled over 33,000 miles per year, the average payback was at approximately 68,000 miles, or just over two years."
I believe we have a member here who might be able to look into the federal results or testing. @Tyson
It was the papers explanation of why they chose not to use a bypass filter but the Fram full flow for gas engines.
The paper stated that non of the manufactures "claimed" to be able to extend the OCI for a gasser. Using only a slightly extended OCI didn't pencil out for being cost effective:
Passenger Car Filters
Passenger cars and light trucks are a large portion of the vehicle market. They comprise the majority of private vehicles in the state. An estimated 61 percent of all California vehicles are passenger cars. Meanwhile, light-duty trucks account for 32 percent, with the remaining 7 percent comprised of all medium and heavy-duty trucks. Potential oil savings could be substantial if a suitable filter was found for passenger cars. However, there are few HE oil filter designs claiming to extend oil drain intervals for passenger cars.
Each filter manufacturer underwent substantial research by DTSC staff. This included phone calls and website reviews of major auto supply stores. Staff found several high-end, spin-on filters that contain synthetic media and reinforced structure. However, the Fram X2 Extended Guard, a traditional, spin-on, full-flow filter design, was the only filter located by DTSC that claimed to extend oil change intervals. Its manufacturer claimed an extended 7,000 miles oil-and-filter change interval because of the reinforced, synthetic nylon fiber construction. Its single pass efficiency is approximately 96 percent at 10-20 μm, slightly lower than the 98 percent attributed to other high-end, spin-on filters.
The major manufacturers (Champion, Fram, Purolator, and Wix) also produce most of the fullflow filters that carry other brand names. Many of these “off-brands” are premium filters designed for extra engine protection or heavy duty use. However, during filter selection, staff learned these filters did not claim to extend oil drain intervals beyond the auto manufacturers’ recommendations.
Subsequently, some filter marketers (e.g., Mobil) now offer new products for extended change intervals. Mobil’s filter claims a 15,000-mile extended oil change interval provided Mobil 1 Extended Performance synthetic oil is used. Although synthetic oils have shown growing promise in extending oil changes, they were not part of this study.
Staff also discovered a filter that features a cleanable and reusable screen. This full-flow filter has a metal mesh screen with larger pore sizes than typical bypass filters. Reusable screen filters must be cleaned with a suitable solvent, which generates an additional waste stream. This filter was not included in the study because it was not designed for extended oil drain intervals.
Staff considered bypass filter testing on cars. These smaller-size bypass filters ranged in price from $75 to $122, with filter elements costing from $10 to $15. Even the less expensive of these filters remained too costly to justify an automotive application. The Fram X2 Extended Guard was the only auto-tested filter. Its particle removal efficiency is less than that achieved from bypass filtration. However, marginal oil drain extensions could make an impact since autos generate a large amount of waste oil. By the end of the project, Mercedez-Benz, BMW, Honda, and GM were using oil life sensors, and Ford extended its recommended oil change intervals by 50 percent, from 5,000 miles to 7,500 miles. 12
That study has been discussed a few times before on this site, but it's been a while.
It shows what I've stated many times is true ...
High efficiency filtration is a means to a fiscal savings; it's a ROI tool. You have to do the math and put the effort into the process to get any tangible benefit. BP filters are not a tool to make equipment last longer. They are a tool to extend the OCIs.
Quote from the paper and your highlight.
"The paper stated that non of the manufactures "claimed" to be able to extend the OCI for a gasser. Using only a slightly extended OCI didn't pencil out for being cost effective:"
This is the problem with only using a pencil, with the bypass filter in use, the oil will stay cleaner thoughout the life of the oil, harmfull particles will not be circulating in the engines oil system, the pencil can't think past the cost numbers.
I think these people that did this study called Ralph Wood, this is the time frame when he had his website for his converted Motor Guard M-30, he said he didn't want to tell them a lie, like his filter could keep the oil clean for 20,000 miles without touching it, that is what they were looking for, a 'Magical Filter', he didn't go much farther into it, like telling them it used toilet paper and you change it every few thousand miles, as he knew the government would say that it would create hazardous waste, then they most likely couldn't get their heads around using toilet paper, because it needs to be a professional looking element, encased in plastic or in a nylon sock.
Yes, I read that part but their justification of the cost was not because a BP filter just “cost too much” but these genius state workers only read the advertising.
Which you acknowledge here. lol, I should read all the way to the bottom before responding.
The state is full of moronic imbeciles. It’s why they employ people that “should” be able to accomplish a task but can’t. Those same people end up “supervising” a contractor to perform their tasks for them. I have to deal with it daily.
I tried to explain how VFD’s could save ratepayers money when installed on the ancillary systems of our pumping plants. Even when breaking it down to the hourly kWh rates & individual facilities payback time (shortest was 9mo), the entire premise couldn’t get past their heads. Frustrating endeavor. Ratepayers also absorb the costs associated with fines due to poorly trained & unskilled employees violating industry regulations. Nothing is ever done about that either.
I’ll stop my rant now. Have to pickup my son from school & head in for a night shift
I read most of the report, what I came away with was that the filters do extend the oil life on the big diesels, they can absorb the cost of the of the filters and elements and pay for themselves with saved oil, diesel oil is high tbn and it lasts. The small bypasses for gas couldn't absorb the cost of the filters and elements because the oil doesn't last in a passenger car like the bigger rigs, the only way it would pay for itself is if the cost of the filter and elements was low and adding enough top up oil to keep the tbn up, an old Frantz and a roll of toilet paper wasn't part of the research. :)
They questioned me about 30 years ago. They wanted to know how many I sold a week. They wanted to know if the Motor Guard removed anti freeze. I said if you have anti freeze in your oil you must repair the leak. I could tell they had talked to a salesman that sold the filters with a heating element. Also the Motor Guard didnt remove gasoline. Saying it evaporates at normal oil temperature didnt work.
Wish i lived in the early days to see those flea market and trade fairs when they had those filter demonstration machines, bet that sold a few toilet paper filters back then.
